I came straight home from work and set to work applying the UV blocker to the upper engine cowling, main gear leg upper intersection fairings, lower rudder fairing and also the upper engine cowling oil filler access door.
Upper engine cowling UV blocker applied
Main gear leg upper intersection fairings UV blocker applied
